- Sep 4, 2002
- Nashville, TN
I just found about this place from someone else who had just found it!
Look like a great site.
I am a long time Abit fan (seems like it). I have had an KT7, KT7A, KR7A, now a KX7-333.
I replaced my KT7A because I was trying to fix a problem with Rally Throphy (a racing game). I still have the same problem.
I have three problems:
Jerks or hesitation associated with hd access, I have most of those kinks worked out, I'm not to worried about it.
The second problem is video corruption, It's like the textures get mixed up, it will continue to run for a while, then eventully it will freeze.
The third problem is likely to be caused by the same problem as the second, the screen freezes, and the sound will continue making the same sound and the system will be totally locked up.
When I first got the game I had a Matrox G400. I had the graphics and locking up problem there too, but the game ran fairly smooth if I did not set the graphics too high. I wanted more power so I upgraded my video to a VisionTek GF3 Ti200.
Now I had all three problems. The hesitation problem showed up, I bought more ram, giving me 512 meg. Still had the hesitation problem.
Replaced my elderly Tbird 1.2g with my present XP1800+.
Still hesitates. Played with Via 4-1 drivers and DET's. PCI latency patch, virtual memory settings.. suddenly the problem went away, however I was still haunted by problems 2 and 3, lockups and graphics corruption.
The Visiontek would not overclock very well, so I replaced it with a Gainward, sweet card, but I still had the same problems, plus the hesitation problem came back.
Bought a new Enermax 350 to replace my older 330watt Enermax. Still did not work.
Decided to change the mobo, bought the KX7-333, it's supposed to be stable. Reinstalled windows bare bone, no sound card, modem, no wheel controller, printer, only what I needed.
Installed Via 4-1 4.38 (said to be one of the most stable drivers).
Installed DirectX 8.1, then the DET 21.83
Installed my game and let it loop a replay. It crashes after 1-6 hours.
I bought a new Antec 450 watt PSU, removed my UPS and added a new surge suppresser. Still did not help.
I have the latest bios, 9K and have spent a long time tweaking bios settings.
3Dmark also will lock up after looping for a few hours, Prime95 has only been tested for 3 hrs, left it running today before I went to work.
Tested without the mouse, replaced the keyboard, no cdrom, only one hd...
What else can I try? Perhaps my memory is not combatable?
Its Crucial CT3264Z265.16T DDR PC2100 • CL=2.5 • Unbuffered • Non-parity • 2.5V • 32Meg x 64
http://www.crucial.com/store/listpa...mfr=ABIT&cat=RAM&model=KX7-333/333R&submit=Go
I'm running Win98se, I'm thinking about going to WinXP or swapping mobo's.
At this point I think I have three options:
WinXP
New Mobo
New Ram
Any ideas anyone?
WinXP
New Mobo
New Ram
Any ideas anyone?
