Ok so we are looking at mid size towers?
As for the case you'll want something that has the ability to add fans like this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16811517027
Air flow is very important for overclocking have a look starting here and see if something tickles your fancy , you'll want 2x120 in front 1x120 in the rear and something in the top preferrably 1x120mm http://www.newegg.com/Product/Produ...02&IsNodeId=1&bop=And&Order=PRICE&PageSize=30
This is where I would START with a motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
EDIT: I would also look at gtting something like this as a minimu for CPU cooling if you plan to OC. The stock cooler won't take you very far http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Also one thing you have to consider on that HP case is the Depth. The deeper the case, the bigger the CPU cooler can be. The specs on that HP case lists the depth @ 6.89 inches, this is from the motherboard back plate. Once you add the standoffs and the motherboard into the mix, you no longer have that 6". Here is a cheap but very good Air cooler. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099, but there's a good chance that It will no fit Your Case. Here is low profile cooler, that was made for HTPC http://www.newegg.com/Product/Product.aspx?Item=N82E16835103204.
I am seeing todays deal and there is one I like : what do you guys think about it. It comes with the 2x140 and I can add 1 more 120 to the order?
http://www.newegg.com/Special/ShellShocker.aspx?cm_sp=Homepage_SS-_-P1_11-156-345-_-03102016&Index=1
or something like that?
Big case, good price, free shipping. What's not to like.
Yes unless you want something bigger. Just make sure it accommodates the ATX form factor and has lots of options for extra fans
The H440 looks like a nice case and the M5A990Fx Pro is a good board for Ocing the 965 on. So you have nothing to worry about.I m literally feeling like overclocked with one fan cooled computer case. Burned out after sinking in New Egg Ocean! So I purchased 2 thing at the end.
1- NZXT H440
2- ASUS M5A99FX PRO R2.0 AM3+ AMD 990FX + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
hope that works well for the feature!
Its all ur fault Johan, it came to the point I am looking at between In Win 805 vs Phanteks Evolv But according to the revies they do have air flow option above the average cases. They are just good for look I guess!
Just trying to make your experience more enjoyable sangria
