- Jul 23, 2003
- Dallas, TX
I'm installing a ThermalTake Smart Fan 2 on top my SLK 800A heatsink. I'm putting the thermister under the die, adjacent to the mobo temp diode.
There is a manual switch on the Smart Fan 2 that seems to set the temperature for 'overdrive' fan speeds. I could do some testing with this in an oven (for example) and determine the switching temperature fairly accurately. With this info, I could set the switch in a gauged dial.
Once replaced on the heatsink, with the termister mounted next to the mobo temp diode, I could get an independent temp reading from the fan going into 'overdrive' for matching the diode temp reading.
Make sense? Is there an easier way to calibrate the mobo temp diode? I guess an alternative might be to buy a temp sensor system with accurate readouts. I don't really know what such a thing might be, or how much it would cost.
mmills
mmills
