CPU: Intel i7 2600
GPU: ATI Radeon HD 6870 1GB
Mobo: Asus P8H67-M Pro
HD: 1TB HD-SATAII 7200RPM 32MB
RAM: 8GB Kingston DDR3
OS: Windows 7 Home Premium
I just recently booted my computer up after it had been hibernating for a couple hours and got some odd visuals on screen, the whole thing started pixelating black and white squares and my machine froze up. I was forced to cut power to restart my machine. Well, now that I've restarted it, my machine seems to be running overly hot, sitting at 43 degree's Celsius while idle and fans at medium while it used to sit at around 35 degrees Celsius with fans at low. Also, Smartdoctor is flashing me this warning: "VGA chipset fan isn't functioning well! Replacing with a new fan may be needed."
My real concern is that this system is only about a month old. Should I just take it in to the shop and see what they can do? I'm not experienced with replacing GPU fans.
Thank you.
Thank you.
