- Mar 6, 2002
- Southern Californis
I finally recieved my VH6t mob and set out to see what my 1.3a tuly would do. I had already run the chip in my old standy msi mobo @ 1456. Well my first attempt was to set the fsb @117, no go bad generic ram, I replaced ram with some mitsubishi pc133 and all went well. so I thought lets try the first 4 divider or 124fsb. Forget it increase vcore in steps all the way to 1.8 with vid trick still no luck. as it turns out my best stable oc was 1521 or 13X117fsb. Not great ! I monitored my heat and the chip seems to run at about 35c no matter what speed or voltage ? My opinion is that the 1.3a is not a good oc chip as it is already running close to max for this chip. All you 1.0a-1.2a guys are doing much better.
I then decided to pull my old p3-700 chip out and try it in the new mobo. Well I have had great luck with this chip it is currently running @ 1120 (160fsb) @ 1.82v and stays cool too! 26c idle 29-31 full load. I could go more but I am not to shure about running my fsb over 160 it seems to be fine but not sure how far it is safe to go ? Now thats a Great overcllocking chip !! and even though I can get better clock speeds with the tuly above , My memory and bus is really cooking with this chip and overall I believe its a better system ??
