I picked up an E5200 for fairly cheap, figured I'd pop it in my intel rig and see if it could do better than my wolfdale E6300 because of the higher multiplier.
First I stuck it in and reset the bios, booted up at stock 2.5ghz and auto voltage. Windows 7 installed drivers, reboot. Enter bios, wanted to see what I could get out of stock voltage. After a few trial and errors, about 3.4ghz maxxed out stock voltage of 1.23v. So I decide to increase voltage while leaving it at 3.4, bumped it right to 1.30v, prime95'd it, got an error and quickly my system totally shut down...no BSOD, nothing just shut down. I was like, ummm....OK. So I restart, take the clock down to 2.8ghz, same thing. Take clock back to stock 2.5ghz, shut down. Put voltage back to auto, all is well.
This CPU is used, and I talked to the PO and he said he didn't have any issues he was running 1.35v or something like that with 3.75ghz.
This is the intel rig thats listed in my sig, it has NO trouble at all running the E6300. I've clocked the E6300 as high as 3.9 stable at 1.425v.
So whatsup with this 5200? Any ideas?
