Howdy,
I'm in the middling of pondering the design of my next system. It will be watercooled. I've come across Angel Eye's AkwaFlo RAM cooling component. I'll be using Arctic Silver adhesive to mount the Akwaflo to the RAM (after i've removed the heatspreader of course). My question is: should I use silicone to protect the memory chip pins or is there a better solution? I'm worried I'll go overboard on the epoxy causing the pins to short out. Any feedback appreciated!
