Water pump mounting question?
if its an impeller pump, mount it anyway you like... it might keep air "trapped" a little longer, but it will get out of the pump sooner or later, and then the noise will go away...
B!
Sure is a impeller pump, most used for aquarium / pc watercooling are.. Mount it anyway you like.
Best of luck.
B!
