You mean the C/W of a water-cooling system? Some guy awhile back measured it to be about 0.2 to 0.15 but the fact is C/W measurements are not linear. If you need to know the properties of water at 300K (27'C) then it's:
i get around .18c/w with water....
dangerden maze 1 using a 5 foot tall 4 inch water tower.
still dont have a fan for the water tower so...
my temps are a little high right now
also i am still using tap water.
no water wetter or anything to help lower the temps so....
.18c/w is a little high for a water cooler, but once i get it all set up .15c/w -.1c/w should be obtainable
