ls7corvete said:You shouldnt have a problem fitting everything in the case. its easy enough to mount the rad and res outside with the help of wonderful products like swiftecs radbox.
Make sure everything is secure and you will be fine.
s random said:i dont have a problem fitting everything, and id like to have a reservoir...
my system specs are 6800 msi-k8n neo2 (nf3) amd 64 2800+, im planning on getting all swiftech blocks with adapter to my 6800 and a swiftech 655 pump, i already bought a 77 bonneville heater core.
also id like to know when transporting it i need to make sure its always right side up or can i lay it flat?
s random said:also id like to know when transporting it i need to make sure its always right side up or can i lay it flat?
