- Jan 26, 2007
Well i did OC it and yes it stuffed up again
The same thing happened to my Asus P5K last month, i had it replaced under Warranty because it was found faulty.
Current Rig:
[email protected]
GA-DS3R
2GB Kingston DDR800, 5-5-5-18
XFX 8800GTS
Creative XFI
Antec 550W PSU, 3x18A
Firstly 400FSB, mem 2.0@800mhz, cpu v 3.335, everything else is at stock voltage, locked PCIE@100mhz booted fine at 2.8ghz as you would expect. Went into WinXP and ran Orthos small ffts for 24hours. No problems, temps at 49deg full load. Opened a couple of games and there you go, same problems as last OC. see screenie below.
Before OC:
After OC:
Rebooted, Went back to stock clocks immidiately, into windows, tested game again at stock settings, same problem. Formated hard drive, re-installed XP, drivers, and a couple of games....same problem...took out motherboard, using a spare Asus P5B for now.
Once again the mobo has sustained permanent damage.
BTW it's not the video card or PSU, i had it running for days without problems until OC'ing.
Any idea how this could have happened?
Current Rig:
[email protected]
GA-DS3R
XFX 8800GTS
Creative XFI
Before OC:
After OC:
