Most people that buy a Porsche don't complain about the radiator requirements.....
Like this at the last pic HERE ? Its pretty normal to feel that !
I've actually got a second 775 stock heatsink, it's basically a cooler master "square chunk of metal with fins". Solid aluminum as far as I can tell. For some reason they figured a small cube of aluminum with a couple fins on each side was a good cooler for a prescott machine.
When the motherboard is installed I'm quite confident that that warping will be non existent. Also, I installed my heatsink after I installed the motherboard. This is because the mounted motherboard is within specifications. That way, if it does break when installing the heat sink, either Intel or <insert motherboard manufacturer here> gets to replace the motherboard.
ya if you break a mobo by putting the stock hs on... thats just plain stupid cus that could have been adverted by putting the hs on with the mobo out.
I can GUARENTEE thats what both intel and the mobo maker would say.
heck thats probably what happens in the assembly line for like dell or anyother OEM... the stock hs is put on the cpu with the mobo out of the case probably on some special stand that puts pressure right behind the cpu socket and surrounding area.
andMake sure that you have installed the motherboard to the chassis before you install the CPU fan and heatsink assembly
The reason? A human is incapable of supporting the motherboard in a manner that prevents the bowing of the board like the chassis does.The boxed Pentium 4 processor should be installed after the desktop board has been secured in the chassis.
Taken directly from the manual of the ASUS P5k-premium(Black Perl):
haha ok... id think putting my hand right behind the socket while pushing thoes crappy pins in would provide much better support than a coupla skrews further round the socket.
