Tried this and it did result in a small decrease in noise (5-10% noticable difference), however the whine sound is still there. It seems to be coming from the actual fan bearings so not much that I can do about that except try to change the RPM's.badvector said:Chazza,
If you remove the aluminum thermaltake faceplate it will reduce some of that whining from the fan. I did this with mine for the same reason.
