- May 12, 2008
- long island
building wc system, will likely mount in on the cosmos s 1100 by cooler master chasis.
read the sticky on monthly round up wc components, but i didn't get a good sense of how to stratify value differences among the rad list. i want to go with 120mm x 3 rad with either 3/8" or 1/2" tubing. my nb on the asus striker 2 extreme fits for 3/8", so was thinking about sticking with 3/8" all a round.
originally i was pricing out heater cores and trany coolers but the wifey is pushing for aesthetics.
I guess it is worth noting that i would like low maintenance, LOW NOISE setup, so will likely go with low cfm/ low flow fans x3. maybe an internal 120mm x 2 in addition to the external 120mm x 3 totalling 5 x 120mm rad with fans.
my goal for the system is to cool the cpu, NB, gtx 280HC x3, maybe ram cooling. Once i figure out how, oc'n everything. that being said...
right now 3 rads debating over:
- HW Labs Black Ice Xtreme III Triple 120mm Radiator - Black = ~$65
- ThermoChill PA120.3 3x120mm = ~$135 (crazy - twice the price)
- Swiftech MCR320-QP Quiet Power 3X120mm = ~$50
which would you go with?
any experience with??
satisfied vs dissatisfied???
notable problems with any of the above????
does anyone know why there is such a huge price difference in rads?
where to find honest reviews and test results?
