Which soc value should be prioritized? motherboard or cpu.
Kvaka
IMG_20240106_182945_816.png IMG_20240106_182945_423.png IMG_20240106_182945_107.png IMG_20240106_182945_274.png IMG_20240106_144715.jpg IMG_20240106_125111.jpg Hi, I am trying to customize my dimm, I wanted to start with 1.15v soc. With this voltage value in bios zentimings shows 1.125. The situation is corrected by llc nb 1 then zentimings shows the right voltages, but motherboard shows 1.17v nb/soc
p.s i am worried about the llc and dimm algorithms of my motherboard on 5700x. At memory voltage 1.33 in bios, the actual voltage is 1.35. at 2600 everything was 1 to 1 with llc 4 it was in static overclocked 4100 1.4v
I wouldn't worry about such a small difference in voltage. Negligible. :)
As far as the thread title, I'm not even sure what you're asking. In your images, there's only one SOC voltage.
