I would personally go with the Thermaltake Extreme Giant 3. I have one and this thing rocks with the dual heatpipes. It cost $35 at www.newegg.com and it does an excellent job of cooling. Your other option is going with the VGA Silencer for 15 bucks. They perform about the same but I prefer the Giant 3 . Hope my advice helps!
WTF are you talking about. There CPU and VGA coolers are high quality. There Accessories suck. I dont know what your talking about xb1az3x, but, The Giant 3 is anything but low quality.
Get the new Zalman dual heatpipe cooler. I got one and a VGA Silencer and with the 80mm fan (I swapped it out for a 120mm), it beats the VGA Silencer even. Very good stuff.
Without any fan on it, it's just as good as stock cooling and with a fan, expect a 15-20C drop in temps. Also comes with ramsinks. I'm very pleased with mine.
i dont think the ATI Silencer 1 has ramsinks in the package, i think they mean you have the option to add ramsinks
they say glued because the other versions of the ATI Silencer and NV Silencer have a copper base that extend to form the memory heatsinks (hence not glued)
