- Jan 19, 2003
the "two lengths of tubing, length A and length B" example i dont agree with. are you saying that the 1/2" tubing would let enough water through to fill up the 2"? no way. if that were true, then all the drainage pipes you see going into ponds and whatnot would always be spouting water. just like the CICO philosophy... trickle in=trickle out. the only flowrate difference between the two tubes would be because the 1/2" tubing provides less friction to the water because the contact surface area with the inside of the tubing is less. in the 1/2" 100ft, there would be very little space, if any, between the water and the sides of the tube, but with the 1/2" to 2" the water would flow along the bottom, leaving only the bottom of the water in contact with the tubing.
in length B, the 1/2" diameter section is at the end, not the beginning. The example works, and was meant to try to illustrate in a non-scientific way to Phextwin that his thinking was wrong.
"That constant rate will increase when you remove a restrictive component and replace it with a less restrictive one." This only applies when you actually take the restrictive part out of the loop, i.e. replace 3/8" tubing with 1/2" tubing.
Uh yeah, that's exactly what I just said.
