- Thread Starter
- #21
I'm glad to see that you got it up and stable. Where is the voltage when you are at idle?
As I stated previously LLC at level 5 actually will cause more vdroop than level 1 (no idea why ASRock would number it that way). So if you run LLC at 1 your voltage under load will go up, as opposed to go down (which I prefer as I figure under load it will need more voltage than at idle)
When I idle I am at 1.21 or lower voltage. It goes way up when it goes under load. Temps at idle are rediculas though. I get temps in the 20C range at idle. And that is in summer when it is 90 degrees outside. Ambient temps are about 20C in my room.
This is my first build I have ever done, and I got done building it a couple months ago. So I really have no idea what other MOBO's do with their LLC. Sorry I can't be of help on that.
