why should I return the 800 they are all the same lot as far as I heard only the cco sucks because it is the 133bus stock. I thought that since I am using the 800 cbo @ 100 I could coerce more out of it than my 750. I was using an alpha before my senfu and my buddy had the 800 @ the same fsb posted higher to 125, I have cheezy memory and vid though. So for the marginal cost I gained a few mhz more. I do not see how the stepping is a pain I have my 800 @ 120 all day and it idles with rain 2.0 @ 24c the only thing I don't like is that since I have this bios prob. I can't use the multiplier in soft 111 and I also can't up the voltage I am running stock voltage @ 120 no prob I try to benchmark or burn - stab. test @ 125 and it locks. Also I have to use cpu boost every time I restart and I can't go higher than 120 presently due to voltage. Is there a prog where I can touch the voltage on the fly? like the fsb? If so that would work Any other info would be appreciated thanks spr
