- Jul 23, 2007
- Washington State University
I bought it because its with rebate and promo code and I'm on a budget. The system details are in my sig.
I'm alittle concerned that one reviewer said it has low voltage... will this thing run fine on the setup?
Thermaltake Purepower W0100RU ATX 12V 2.0 500W Power Supply 115/230 V UL, CUL, TUV, FCC, and CB certification
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052
Brand Thermaltake
Model W0100RU
Series Purepower
Type ATX 12V 2.0
Maximum Power 500W
Fans 1 x 120mm fan
PFC No
Main Connector 20+4Pin
Dual +12V Yes
PCI-E Connectors 1 x 6Pin
SLI Support No
Modular Cabling Support No
Power Good Signal 100-500ms
Hold-up Time 8ms(minimum) at 80%
Efficiency > 70%
Over Voltage Protection +5V output 6.25 0.75 V
+3.3V output 4.0 0.30V
+12V output 15.0 0.6V
Input Voltage 115/230 V
Input Frequency Range 47 - 63 Hz
Input Current 9A @ 115V, 5A @ 230V
Output +3.3V@22A,+5V@32A,+12V1@14A,+12V2@15A,
-12V@0 .3A,+5VSB@2A
Approvals UL, CUL, TUV, FCC, and CB certification
Connectors 1 x Main connector (20+4Pin)
1 x 12V (P4)
8 x peripheral
4 x SATA
2 x Floppy
1 x PCI-E
Features Complies with ATX 12V 2.0 Version
Low noise 12cm fan and mirror effect casing
Protections against Input Protection, Over Power, Over Voltage, Short-Circuit, and No Load Operation
Thanks for the help
Brand Thermaltake
Model W0100RU
Series Purepower
Type ATX 12V 2.0
Maximum Power 500W
Fans 1 x 120mm fan
PFC No
Dual +12V Yes
SLI Support No
Efficiency > 70%
-12V@0 .3A,+5VSB@2A
1 x 12V (P4)
8 x peripheral
4 x SATA
2 x Floppy
1 x PCI-E
Thanks for the help
