- Apr 14, 2003
- Phoenix, AZ
2T's is for me... I always get the name as a user...Dual Core Joe said:Yes that is a nice wire job. There is only ONE T in Ducati.
1T for the bikes however...
Bad Maniac said:I'm talking about keeping the CPU at a temperature where it will operate without errors, thermal throttling or CPU life time reductions. For THAT, a single rad is "plenty" To keep the same setup at a fixd temp above ambient, yes, you need a bigger rad, but why would you want to?
Trike007 said:Yeah i'm aiming for max overclock. So i'm toying with the idea of adding my X1950xt to the loop. That card runs hot as it is, but i don't want to risk a huge increase in temps if I add it to the loop. what do you guys think? I had one of those. "might as well" kind of moment.
S-I-L-E-N-C-E... same cooling performance as mid range air, much less noise. Most vid cards have extremely noisy fans, so even with silent air on the CPU, water will still cool CPU and GPU as much as, if not more, than air, and at much less noise.wombat778 said:Besides which, your recommendation would not make sense for almost anyone:
Bad Maniac said:S-I-L-E-N-C-E... same cooling performance as mid range air, much less noise
In this case, no. But there are times, on older systems, where a single rad does quiet things down a lot - and reduces maintenance too ...wombat778 said:<snip> So, it still doesn't make much sense to go with a single rad even for the silence crowd. <snip>
QuietIce said:In this case, no. But there are times, on older systems, where a single rad does quiet things down a lot - and reduces maintenance too ...
