- Mar 13, 2004
- USA, Vermont
So when the new Winchesters coom out with SSE3 they will b SS and a new steping to boot.
Dukemurmur said:So when the new Winchesters coom out with SSE3 they will b SS and a new steping to boot.
hitechjb1 said:What 5-letter stepping is it? CBBFD or CBBGD?
You may also want to enter your result in
A64 Overclocking Result Collection
majinwar said:i talked to a guy about this SS issue (owner of a big computer company) and he said that it is most likely just a rumour, so i wouldnt be worried about it too much.
crimedog said:90nm is just maturing... if they had gone to SS we'd probably see jumps in overclocks like we saw FX-53 to FX-55
Overclocker550 said:he got the strained silcon one, that explains the 2.8GHz clocks. The fx55 with its ss has been seeing easily 2.8GHz, some even 2.9GHz with adequate air cooling. AMD has a small number of winchesters with SS but soon all of them week 45 and newer will use SS. If mine isnt SS I will just sell this and buy a 3000+ maybe 3200+ if I need the 10x multi with SS and ill have about 2.85GHz
I assume for A64's? Here you go.jarthel said:can someone post a link on how to understand that AMD code printed in the CPU?
Thanks
Overclocker550 said:a small percentage of pre week 45 are believed to be SS, this is the more likley outcome than his cpu being "super pure"
crimedog said:That is crap. The average oc for winnies has been rising... 2.6 to 2.7 to 2.8
FX-53 to FX-55 gained a ton of clock speed with the introduction to SS. Way more than 100mhz.
You also can't compare the FX to the winnies, the fx has twice the cache (amongst other things).
Stop spreading this half-cocked theory about SS.
dippy_skoodlez said:The fact that the fx-55 is 130nm, and winchester is 90nm and the FX is still getting better clocks, is decent proof of no SS yet, highest winchester I have seen is charlies 3.2, but Ive seen an fx-55 at 3.8. 600mhz is quite a gap. Dont forget, 130nm Vs 90nm, aswell.
AMD is gonna eventually use SS on all of the CPU's anyways. They announced support for SOI and SS a long time ago. why is everyone all amazed at it? With winchesters arleady hitting 2.8 or >, easily, w/out SS, then I can't wait for SS to kick in!
Quailane said:Can you post links to this speeds?
