Hello guys , i am planing to build wooden pc case after new year , so for now i am colecting info for the materials . My main reason for this is because my old case was builded so badly my videocard drop 10 degree celsius just because i pull the system out of the case , also i am a bit afraid with the case being made with only wood the temps will be actualy higher and also i wanted to make it silence and what do you guys think of EMI/RFI Shielding if i should take in consideration to somehow protect from them and acousting foam? I wanna have room in it so i will build a large one , also i want to build piece by piece like lego or something , if i need something a little bit different ( maybe a new cooler or something like that) so i could just replace that piece . And i was thinking about how the motherboard screws will fit in wood and i was thinking at those screws
to screw it on the wood and then screw the motherboard in that screw or if you guys have something better i am eyes and ears . I really want to hear your suggestion and opinions about this
My rig :
Cpu: i3 6100
Motherboard: Msi z170a gaming pro
Videocard: Gigabite gtx 780 winforce x3
Cooler : corsair h80i
Psu: Sirtec High Power Element Smart 750W
Hdd:1
Ssd:1
My rig :
Cpu: i3 6100
Hdd:1
Ssd:1
