- Jan 30, 2010
- La Crosse, WI
So the simply run down on what I'm trying to do here is this... I'm trying to shoot a bullet and I want said bullet to follow a vector towards the mouse. Now currently my code DOES this but the bullet stops AT the mouse. I want the bullet to continue on until it leaves the edge of the screen. How can I go about doing this?
This calculates the distance between the bullet and my mouse using Pythagorean therm.
This launches the bullet
Any help is greatly appreciated because I'm totally stuck here...
Code:
private float calculateDistance(Vector2 A, Vector2 B)
A = new Vector2(Math.Abs(A.X), Math.Abs(A.Y));
B = new Vector2(Math.Abs(B.X), Math.Abs(B.Y));
float Y_diff, X_diff, distance;
Y_diff = A.Y - B.Y;
X_diff = A.X - B.X;
distance = (float)Math.Sqrt(Math.Pow(X_diff,2) + Math.Pow(Y_diff,2));
return Math.Abs(distance);
Code:
//define some variable for later on
Vector2 mouse_pos = new Vector2(MS.X - bullet.Width/2, MS.Y - bullet.Height/2);//where mouse is
Vector2 direction = mouse_pos - position;//get xy diff
float distance = calculateDistance(mouse_pos, position);
velocity = Vector2.Zero;
if (direction != Vector2.Zero)
direction.Normalize();
if (MS.LeftButton == ButtonState.Pressed)
if (distance < baseSpeed)
velocity += direction * distance;
else
velocity += direction * baseSpeed;
position += velocity * baseSpeed;
