- Jul 3, 2001
- Houston Texas
I am trying to replace the growling fan on a Vantec CCK-7015, with a Y.S. Tech TMD fan. http://www.directron.com/cck7015.htmln <Is a pic of the heat sink. Since both fans are 70’s the TMD fan will fit on top of where the original fan is screwed in from the top with pretty much standard type self threading fans screws. Just wondering if you guys think I can get away with using the self tapping screws with the TMD fan without messing it up. Started one of the screws and it didn’t sound like it was liking it at all. Anyone seen a TMD mounted with the self tapping screws??? Really do not want to go buy a 70X10 fan when I have the TMD already.
