ASUS C90 Overclocking Laptop
A close look – Joe
SUMMARY: Part I – A look at this laptop’s specs.
Pic
Pic courtesy of Directron
The good guys at Directron were nice enough to help get a loaner of the ASUS C90 Overclocking Laptop (ASUS site here) to me so we could take a close look at what is one of the few true overlcocking-capable laptops available. One of the main attractions I see (in addition to the OC) is that it makes servicing and updating the laptop over time much easier than the not-user-friendly offerings from other manufacturers.
First we’ll take a look inside and then cruise the specs that define what this laptop can do.
The back comes off easily by removing five screws:
Pic
A closer view shows the area surrounding the CPU socket:
Pic
This shows the fan bay – there is a CPU cooler that will fit in the right hand side:
Pic
The back view shows the four cooling fans – these are Delta each rated @ 9500 rpm, 13 cfm, 36.5 dBA. At full tilt, these four fans must make a racket; however, there is software in BIOS that controls fan speeds based on temps, so they should be moderated in use.
Pic
Feature List
Asus’s website lists part of the features that this laptop should support as shown below:
Key Features:
Processor & Cache Memory
LGA775, Supports Intel ® Core ™ 2 Extreme processor up to X6800, 4MB L2 Cache, 2.93GHz, 1066 MHz FSB
Support Operating System
Windows Vista ® capable
Chipset
Main Memory
2 SO-DIMM Sockets for Expansion Up to 3GB
Support up to 3GB Dual Channel DDRII 533/667MHz SDRAM
Video Graphics & Memory
NVIDIA Mobile PCI Express Module up to GeForce 8600M GT 256MB/512MB
Display
Up to WSXGA+(1680×1050) Color Shine 15.4” LCD
Hard Drive
Supports 2.5″ 9.5mm SATA HDD
160GB: supports 7200RPM
Thermal
fan-control & multi-heat pipe thermal module; Four Delta AFB0412VHB fans, each rated @ 9500 rpm, 13 cfm, 36.5 dBA
Optical Drive
5.25″ 12.7 mm 8X / 24x24x10x(max.), support DVD Combo, DVD Super-Multi, HD DVD and Blu-ray Drive
Video Camera
2.0 Mega pixels rotate CMOS Camera with Face tracking function
Card Reader
8-in-1 MMC/SD/Mini-SD/XD/MS/MS-Pro/MS-Duo/MS-Pro-Duo
Fax/Modem/LAN/WLAN
Built-in 10/100/1000 Mbps LAN
Integrated V.92 MDC Fax/Modem w/ Azalia Ver 2.1 compliant 802.11 a/b/g/n
Optional built-in Bluetooth ® V2.0+EDR
Interface
1* e-SATA Connector
1*HDMI
1* D-Sub VGA Port
1* Headphone-out Jack(SPDIF)
1* Microphone-in Jack
1* RJ11 Modem Jack
1* RJ45 LAN Jack
3* USB 2.0 Ports
1* TV-Out (S-video/Composite Video)
1* IEEE 1394
1*MCX connector for TV-RF
1*Express Card 34 / 54 Support
Audio
Built-in Azalia Compliant Audio Chip
Built-in high quality speakers and 2 internal microphones
KeyBoard
19 mm full size with MS-Windows function keys
2.5mm travel
Vista K/B Start Button
Hot Keys
Power, Turbo Gear, Internet, Email, Touchpad Lock
AC Adapter
Output : 19V DC, 4.73A, 90W
Input : 100~240V AC, 50/60Hz Universal
Battery Pack & Life
Li-Ion 6 cells: 4800mAh, 53W (removable): Smart Battery, 2.5hrs Quick charge 95% (Power Off) / 4hrs (Power On)
Dimension & Weight
14.4 x 10.5 x 1.3~1.7 inch
6.8lbs (with Battery)
Supplied Accessories
Built-in Bluetooth V2.0+EDR
Finger Print Recognition
TV Tuner (optional)
Carrying bag
Table courtesy of ASUS
The above table tells part of the story – for more details, I went to Intels site and found the following specs from Intel ® 82945G Features document:
Processor Interface
  • Intel ® Core 2 Duo, Intel ® Pentium ® 4 processor in the 90 nm process in the LGA775 Land Grid Array package or Intel ® Pentium ® D processor (supports 775-Land package)
  • Supports Pentium 4 processor FSB interrupt delivery
  • 533/800/1066 MT/s (133/200/266 MHz) FSB
  • Supports Hyper-Threading Technology1 (HT Technology)
Note that this laptop supports only Core 2 Duo – it would have been better if the other CPUs were supported, especially if you have some CPUs you’d like to recycle.
System Memory
  • 4 GB maximum memory
  • One or two 64-bit wide DDR2 SDRAM data channels
  • DDR2 400, DDR2 533, DDR2 667
  • Bandwidth up to 10.7 GB/s (DDR2 667) in dual-channel Interleaved mode.
  • Non-ECC memory only
  • 256-Mb, 512-Mb and 1-Gb DDR2 technologies
  • DDR2-667 4-4-4 is not supported
  • The speed used in all channels is the speed of the slowest DIMM in the system
No real suprise here except that you have a wide range of choices.
Graphics Features
PCI Express Graphics Interface
  • One x16 PCI Express port
  • Compatible with the PCI Express Base Specification, Revision 1.0a
  • Raw bit rate on data pins of 2.5 Gb/s resulting in a real bandwidth per pair of 250 MB/s
This supports the PCI graphics slot.
Integrated Graphics Device
  • Core frequency of 400 MHz
  • 1.6 GP/s pixel rate
  • 3D Graphics Rendering Enhancements
  • VLD/iDCT for enabling dual Intel ® High Definition streams for MPEG playback
Note also that the chipset supports both analog and digital video output.
Analog Display Support
  • 400 MHz Integrated 24-bit RAMDAC
  • Up to 2048 x 1536 @ 75 Hz refresh
  • Hardware Color Cursor Support
  • DDC2B Compliant Interface
Digital Display Support
  • Two SDVO ports multiplexed with PCI Express graphics interface
  • Can combine two channels to form one larger interface
  • Flat panels up to 2048 x 1536 @ 60 Hz or digital CRT/HDTV at 1920 x 1080 @ 85Hz
  • Dual independent display options with digital display
  • Supports TMDS transmitters or TV-Out encoders
CONCLUSIONS
So far so good – the physical layout is easy to get to and work on and the feature list is impressive. Once I get the CPU to take it for a test drive I’ll report back on how much overclocking this laptop allows.
{mospagebreak}
The Barebones Experience
If you’ve built your own PC, rounding up the pieces for a laptop and assembling it will not be a big deal. However, be forewarned:
THERE IS NO ASSEMBLY MANUAL
What you get is a bunch of little plastic bags with tiny screws in them and two heatsinks – one for the CPU and one for the GPU. The Manual that ships with the laptop explains how to turn it on and what the buttons do – that’s it. You have to figure out where these tiny screws go and how to shoehorn the heatsinks into place. The mechanically-challenged should avoid the barebones experience.
In my case, the ASUS C90S needed the following components:
  • Desktop CPU
  • Videocard
  • Memory
  • Hard Drive
  • WiFi Card
  • OS
The good guys at Directron supplied the CPU (an E6320) and videocard – the ASUS nVidia GeForce 8600M GT 512MB (there is a 256 MB version available HERE.) It has a plate on the top onto which the GPU heatsink mounts – you figure this out by looking at the parts you have and then have an “Now-I-see” epiphany. The epiphany was what to do with three tiny spring-mounted screws – “Now I see – they’re for the GPU heatsink!”
A word on the CPU; ASUS will tell you that the E6320 is not supported – according to ASUS:
“The C90S supports Core 2 Duo (Conroe) “E4300, E6300, E6400, E6600, E6700, X6800″. Core 2 Duo (Merom) NO, Core Duo (Yonah) NO, Pentium M (Dothan) NO, Celeron M NO. E6320 is a newer Conroe and unfortunately is not supported by the C90S.”
I relate this because I found this out after I asked Directron for the E6320, as the spec sheet was not as specific on what CPUs are supported as my subsequent inquiry. As I found out, the E6320 will work fine as will the E2160. This is the fun part of the barebones experience – finding out what works and what doesn’t (as an aside, I also found out that it runs without the battery installed).
For the RAM I decided to buy some cheapo PNY – I wanted to see if this would work and it did – no problem. The only other part was the hard drive and that’s a no-brainer standard part. I did not use a WiFi card as I have sworn off wireless routers, so I can’t add anything on that.
I had some questions and I called ASUS laptop tech support – it’s available 24/7 and it’s really true – I called on a Sunday night and got a live tech located in California. This was almost a jaw-dropping experience – no wait. However, you must accept that the more esoteric your question, the less likely you will get an answer. Let’s face it – the techs can handle the routine stuff easily – anything that’s outside the script is a crap shoot.
Even so, I was pleasantly surprised with ASUS tech support for laptops – nice guys trying their best to be helpful.
Overclocking the ASUS C90S
ASUS is marketing the C90S as an “overclocking laptop”, so that’s what I concentrated on trying out. I installed the OS (XP), booted into Windows and then installed all the drivers that ship with the C90S. The screen on the C90S is stunning – native resolution is 1680 x 1050; for some of the veterens among us, you may have to adjust text size – for me it was a bit too fine but setting text size larger fixed it.
The C90S is “certified” for Core 2 Duo E4300, 6300, 6400, 6600, 6700 and 6800. Naturally the first CPU I tried was an E6320 to see what else worked:
Pic
Booted up and ran fine – no problems. I would have thought this to be the case as it seems the only significant difference is the cache size – 4 MB vs 2 MB for the others. The Intel 945G Express Chipset supports FSBs of 533, 800 and 1066. On the off chance that somehow a pad-modded CPU to 1333 would work, I tried but no joy. As the chipset supports Pentium D, I tried that also but no joy on that one.
Next I decided to throw in an E2160 that I pad-modded to 1066 – this is the CPU that came with the Dell Vostro 200 that I reviewed HERE. I figured since the chipset supports 1066, this should work OK – and it did:
Pic
Summary: Laptop Barebones is not complicated, but knowing what goes where helps.
The ASUS sells the C90S as a barebones laptop, which is a great move for those of us who like to roll our own. However, the Manual available from ASUS is NOT a “How-To” manual. As an example of what’s involved in setting up a bare-bones laptop, I wrote the following How-To as an example.
Opening the Back
I think one of the positives for a barebones laptop is the ability to perform routine maintenance, such as cleaning dust from the heatsinks – trying this on some laptops involves a level of disassembly that turns into a daunting task. The back of the C90S:
The back plate comes off after removing only four screws – they are identified with the following symbol:
Back Screw Detail
The four screws are located as shown in red:
Back Screws
Remove the screws, then SLIDE the back cover off by pushing it from the front towards the back – then you see this:
Start
Remove the battery when working on a laptop – you don’t want live circuits.
Videocard Install
The C90S needs a videocard, so installing one is a necessary step. When the laptop is shipped without a videocard installed, the VGA area looks like this:
VGA Slot
The heatsink you see here is for the northbridge chip. The videocard installs easily into the slot – as with RAM, it goes in at an angle:
Videocard Install
Next take two small screws and while holding the videocard down against the screw posts, tighten the screws:
VGA In
The two screws to hold the videocard in place are circled in red – the arrows point to the mounting holes for the VGA heatsink – it’s the smaller one included in the parts that ship with the C90S. The VGA heatsink’s base matches to top plate of the VGA card:
VGA Heatsink
Line it up and similar to the CPU heatsink, wiggle it into place – it’s in place when the three holes in the heatsink mate to the three holes in the videocard’s top plate:
VGA Screw Holes
You’ll find three spring-loaded screws in the parts packages – these are for the VGA heatsink.
VGA Screws
Snug them down and that’s it! The CPU and VGA heatsinks are the most difficult tasks – installing the hard drive and RAM will complete the build.
VGA HS Installed
CPU Install
Installing the CPU is absolutely straight forward – the C90S uses desktop CPUs, so the socket is a standard desktop socket. Line up the CPU to the socket’s index pins, and close the socket.
CPU Socket Open
Add some thermal grease and then slide the heatsink’s fins into place. You have to keep the heatsink almost touching the CPU as you slide it into place – you may have to wiggle it into place. Once in place, then tighten the heatsink in place with four small screws:
CPU HS Installed
If you remove the heatsink, the thermal grease acts like a suction cup – you have to move it around and lift the heatsink to break its grip.
Installing RAM
RAM is the easiest – there are two RAM slots. RAM is installed at an angle; once securely in the socket, push down and it will clip in place:
RAM Install
After all these steps, the C90S will look like this (ex the hard drive):
Done
Note the location of the two heatsinks – the fins fit snuggly into the fan bracket assembly; be patient, you may have to play with it to get it in place. Whatever you do, don’t force anything!
Hard Drive Install
Piece of cake – there is a hard drive bracket which will attache to the hard drive:
HD Cage
Without the bracket the drive will not be secure:
HD
Screw the bracket to the drive and slip into its connector:
HD In
Last step is to secure the drive in place with two small screws, located as shown in red.
Other Cards to Install
I did not install the WIFI card on this laptop, but its located at the upper right hand side of the motherboard.
Conclusions
Finishing off a barebones laptop is not difficult, but it would be nice to have a Manual to guide you through what goes where and how. The benefits for me far outweigh the discovery process you may have to go through. I gave ASUS high marks for marketing barebones laptops, even lacking an assembly manual.
  1. Asus M6NW20 Laptop User Review
  2. DIY Laptop Repairs
  3. Watercool A Laptop??
  4. LapWorks Laptop Legs
  5. ECS G733 Laptop Review
Tags:
