Archilochus,
Great minds DO think alike apparently.
Your latest cooling mod is eerily similar to mine with one major difference.
Your mid-case fans must be drawing air from the front quadrant of the case, fed through the two stock front fans ( which are fed through the HDD bays still, right?).
My plan is to draw air from the center of the case floor.
This naturally meant yet another hole in my case. It is beginning to resemble a piece of Emmenthaler cheese at this point.
Poor baby.
So, for the upteenth time she was stripped naked and my nibbler went to work.
While I was at it I decided to enlarge the roof vents. Partially this was done to help the natural convection flow, partially to accomodate the upcoming radiator mount for water cooling and partially to standardize the look of all the vents. The outside now looks like this...
No comments about Bunn coffeemakers please.
The opening for the floor fan was also cut and temporarily a grill was mounted while I work on the new fantower.
The plan is to have a 120mm fan laying on the floor with a plexi ( hopefully) tower rising up and terminating with two 80mm fans pointing directly at the HSF unit. This ( anticipated) blast of air is then expelled out the stock rear fan openings. I shall try it first
sans fans on the back wall...they can be added if necessary.
Here is a bad shot of the floor vent. I was too lazy to remove the sidepanel and set up a good picture as I am running a stress regime to see how she's running with this setup (Folding and 2hrs of Burnin test) before I continue work tomorrow.
Told you it was bad.
Sprocket's saga shall continue...
