$1000 dollar build help
Run from that PSU like the plague.
Check out the Seasonic G-550.
Much.
No sense in building a nice computer and having the part giving it all power being inferior :)
For the RAM, I would get this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231546
Better timings, better company.
Past that, everything looks good.
Either the Intel or AMD setups will serve you well, even in overclocking.
I would consider a different case that comes with more fans unless you plan on buying some.
I'd get these sticks over the ones you picked
And this power supply
If you're questioning which build the Intel is a no brainer for gaming!
