might you be able to direct me to a 120mm to a 140mm cpu fan that spins continously at 12000 rpm,and that connects directly to the 12 volt rail that runs off of my 850 watt power supply,bypassing the 3 pin connector on my pbz875 chipset intel motherboard???, wouldn't the 3 pin connector only act as the sensor that regulates the fan speed in this case???,thus severely limiting how fast the fan will turn?,since the bios system has a stupidly low fan speed regulator program built into it,and,as I understand the intel website,is not backwards compatible,I flashed it to the lastest bios,which turned out to be a big mistake,for the aforestated reason, also,the cpu fan would have to be socket 478 compatible,since this is a socket 478 system!!!,thank you very much,for your time,your courtesy,and your consideration in this matter
