- Oct 18, 2011
I'm planning to order the fan filter set by DEMCiflex from FrozenCPU soon for my HAF 932 and was also planning on ordering some fans from newegg, but it makes a lot more sense to just order them from FrozenCPU and combine the shipping fees (since they'll both be coming from the states anyways). I wanted to grab some red LED 120mm fans to match the front of my case and improve cooling performance and I'm unsure as to what I should order. I'm replacing the side 230mm fan in my case and looking to spend under 15$. The specifications page of the case manual states that they rotate at 1700 RPM with 19 dBA.
I've narrowed it down to the Yate Loon Clear medium speed fan, the Thermaltake Thunderblade Super Silent fan and the Coolermaster Sickleflow Super Silent fan.
I'm leaning more towards the Sickleflow's, even though they cost a bit more and do push a little less air. I'm not sure I could live with the specified dBA that the Yate Loons and Thunderblades produce. Should also mention that I don't want the space around my feet lit up like day. I'm open to other suggestions and I'm curious as to whether anybody has any experience with these fans and can provide some constructive input. If buying plain fans will grant me a huge boost in cooling performance at the same price point I am open to suggestions on that score as well.
And since I know budget is key here, I'm looking to spend under 15.00$. If for some odd reason my computer specifications are of use, they're in my signature. Any help is appreciated.
