I noticed your FSB speed (noted in CPU Z) is still 242? Trents and I were suggesting dropping this to 200 and then using the multi's on your CPU and NB and to overclock. But if this is working out for you, that's great. I know I always say this but try to get your nb speed up to 2600 or 2800. Above that its hit and miss, but thats one of the best NB chipsets you can get for the Phenom II platform, so I bet you could get 3000 mhz out of it.
Your core temps look great but your CPU socket temp at 61c max is getting real close to the stable limit which we consider to be about 65c. Can you put a spot fan to blow on the VRM/socket area of the motherboard?
Also, watch your ram frequency. You are now at 1600 mhz and I would not think a Deneb core CPU IMC will take any more. If there is still overclock headroom for the CPU cores then you will need to drop your ram speed back one level so that you continue to bump up the FSB. Does that make sense?
I would now move from 20 minute Prime95 blend stress tests to 2 hr. tests. 20 minutes is not long enough to really confirm solid stability.
He is running a thuban based processor, not a denab. As advertised, and delivered, the thuban IMC has better reliability and potential for over clocking, beyond speeds of 1600mhz. Combined with the 890gx nb, much higher ram speeds are now attainable with new boards.Also, watch your ram frequency. You are now at 1600 mhz and I would not think a Deneb core CPU IMC will take any more. If there is still overclock headroom for the CPU cores then you will need to drop your ram speed back one level so that you continue to bump up the FSB. Does that make sense.
Generally, mixing pairs of ram of different makes and different timings and or different voltages is not a good idea for stability but if timings and voltages are the same or very similar it often poses no problem.
Hi Mandrake4565...i had that problem when the cooler was placed with the fan pointing down...now with it on is normal position i dont have the problem anymore so its more simple to switch the RAM's to test them...Kelsinni, if you put the fan on the other side of the cooler, in a pull configuration will it help you fit the Team Dram in?
Hi trents...They have the same voltage 1,65v and i have already run the TeamGroup module at 1600 CL8. The OCZ module is CL7 by default but i think it could be set to CL8 without problems...
My question is 8gb in total are really necessary?
Other option that i have not mentioned was sell both modules and get a new 2x4gb module with good timmings...what do you think?
I go for this last one. Get ram that runs at 1.5v instead of 1.65v and get some without tall heatsinks. I really like GSkill products.
Thks
