- Apr 20, 2004
- JAX, Mississauna
What ram you run is really not of consequence to us since it is your ram. If you set the ram timings to the slower set and THEN insert the faster ram it should be setup to run at the slower rams settings since slow ram cannot run at the settings of the fastest ram in general.
I have run mis-matched speed and ram timings sets of ram plenty of times, using the timings and speed of the slowest ram on the faster ram. I have even changed the ram sticks SPD on the faster ram to match the slower ram so there was not any problem with the bootup if i forgot to setup ram for slower before booting.
The only time I have ever had issue is when a fast type ram would not run at the normally tighter timings of the slower ram and that does not happen often, BUT it can depending on some very odd circumstances of how the ram is binned and spec'd to run.
So do as you wish with the ram. Only at your end can you prove out what will and will not work. Good luck.
RGone...
RGone...
