This might be the highest stable overclock that I can get on my Diego at 1.55 volts. If my motherboard allowed for higher volts than 1.55 I could see myself getting 3.1 stable at 1.60 volts.
Don't count on 3.1 @ 2.6V.I'm doing 2.9G @ 1.525 but when I'm trying to get to 3GHz it needs more than 1.67 V to get stable.So it might won't be so easy to reach 3.1G or maybe it is...
Nice OC man but I agree with Andreas1327, 3.1ghz is probably slightly on the optimistic side (not that its a bad thing!).. also, that sshot shows you at 1.584V, so i would imagine an extra ~0.025V isnt going to give you another ~210mhz oc but as above
Yea I think that CPU-Z reads my motherboard wrong because in the BIOS I set the volts to 1.55. I can hit 3.0 Pi32 stable but I feel comfortable at 2.97. I dont think that im going to upgrade my ram since 2 gigs of ram at decent timings while running about 40mhz above stock is good enough for me and I got 28 seconds in PI 1M so im pretty happy with the results.
My temps are around 54C load and 38C load and they are lower depending on my room temperature. I can tell everyone that I have a 3.0 Diego because its stable but I feel comfortable at 2.97. 3.0 on air with a Diego is pretty crazy though especially at low volts.
