7M FTW
7M FTW
I hear ya. I'm putting a 7M into an 86 4Runner (to be honest, that's eaiser than what youre doing). I did contemplate a 4G63 into my 84 Starlet, but in the end I wanted to keep it all Toyota, so a 3T-GTE is going in instead.
Almost did a 3S-GTE swap into a 93 MR2 I had (It was the NA version)
Man... I didn't know we had so many gear heads on this forum! I guess it all goes hand in hand. If you love to build and work on "things", it usually goes for most everything in your life.
Helped build a hybrid 5S-GTE for a NA MR2 a few years ago. The 3Ts are a bit older than the 3S'... stout little motors though, and cheaper to get power out of, which is what I'm all about... which I guess helps explain the overclocker thing too.
I hear it's common to put the Toyota 8" rear-end in those Mighty Max's... if you get the 4-pinion carrier, I think I have a 4:30 LSD lying around you can just take if you need it... you'll definately have to rebuild it though.
