3rd GPU covers Audio and USB3.0 connectors on mobo
Hi
About to install a 3rd GPU on my Asus X99A-II mobo in the recommended 4th (bottom) PCIe slot but I see that it is going to cover both my front panel audio and USB 3.0 connectors.
What can I do?
Doesn't matter although you should definitely have a card in the 1st slot. Personally, I just put them in slot order so 3 gpus, then slots 1, 2 and 3. For you...1, 2, 4 or 1, 3, 4 or 1, 2, 3 will all be fine.
