He is thinking about it in a GAMING capacity which you cannot do.Well, you can mix and match GPU's AMD and Nvidia will work in the same rig, just no PhysX
As far as using PhysX with an AMD GPU as the primary, there is a hack for that...
As far as using PhysX with an AMD GPU, there is a hack for that...
(more learning, less spreading of false information please!)
Yeah, I know they would say "sorry outta luck" if I told them I overloaded it with 3 GPU's
And if they saw something like burnt pins they would most likely say "PSU's fault, not covered".
Trust me, I've seen it done before. Companies will run between the lines any time they can to avoid returns.
Que? What were you testing? Not the 12v as that is a whopping 50W for your system, which, from what you posted is what I thought you were testing?I averaged 3.8 Amps, and saw spikes of 4.2 Amps.
With that beastly PSU in mind, that will safely power the whole rig?
You really got me thinking about my old mobo and how I killed it + the replacement plan I got and it's T&C's. I'd hate the thought of kiling another one.
Oh, 1 small detail left out:
The 7850 will come with a SATA -> Molex -> Pci power connector
(If needed anyway)
The 120V off the wall.
The 850 would be enough for you to add another 270X.
I'd trust that Seasonic past the sticker rating, honestly.
You'll have 6x 6+2 PCIe connectors on it, which should be enough for your system to not use adapters, right?
If not, plenty of Molex/SATA to steal.
Single 12V rail at 70A, that'll run you for quite a while.
Since you are new to the website Silver, I will point you to the link in my signature for quality PSU's.
504W PEAK actual use with all three cards and the CPU at 100%... That leaves a little less headroom than I would like to see, but... a quality PSU should do that no problems.
Then perhaps something in the 750W range since we now know he uses 504 at PEAK with two. Adding in the other GPU only lands us at what 650W PEAK?
