- Aug 2, 2012
- Dayton, Ohio
- Thread Starter
- #81
before i wash it should i put my PII 4x 810 in there to see if its the cpu?
Someone (RGone, I think) suggested squirting carb cleaner on to pasted CPU pins will work. Maybe it would work for a pasted socket, too. I would try that first. Less hassle and that stuff evaporates fast.
Oh well stuff dropped on the traces of the board maybe a bad thing.
if you will reset bios to default.
in aisuite i want to to adjust only 2 things.
#1 set cpu ratio to get 4400.
#2 set core voltage to 1.40.
stress test this for 30 minutes in prime 95 wathing core temps to besure that they stay at or below safe limits.
4.2ghz is stock!
Follow caddi's advice, reduce vcore notch by notch till you crash. Up it one more and prime, rinse and repeat till you are stable running prime95 small fft's for 30 min.
not blend?
and what about cpu nb voltage?
