- Nov 8, 2001
I just finished the first official version of Overclockix, which is a customized Knoppix 3.2 CD. It runs from a cd-rom and in ramdisk, but there is an install script to stick it on a HDD. The procedure is realtively painless and takes about 30 minutes if you follow the instrcutions on www.knoppix.net/docs
Once installed to a HDD, it is Debain. So you can see that using any variety of knoppix is a quick and easy way to get Debain installed. Mmmmmm, apt-get......![Drool :drool: :drool:](/forums/oc_images/images/smilies/slobber.gif)
But it works just fine running from CD, though is naturally a little slow to load things.
Anyway, its got a lot of packages, except for games. Its geared toward desktop use, but also has a lot of burning applications, DC clients, network tools, and filesystem tools. So its a good system recovery disk, and also an instant way to burn-in a new machine without having to install an operating system. I find that knoppix auto-detection scripts really help you out if you have linux on your HDD, because they can generate config files for you if there is a problem on your system. Just boot the CD, mount the hdd partition and cp the file over.
It has KDE3.1, Fluxbox, Icewm, and twm for window managers.
Opera
xchat
gaim
gimp
xmms
xine
karamba
openoffice
ncftp
Apache
VNC
mozilla
dbench
cpuid
folding@home
seti@home
prime95
memtest86
and thousands more...
Normal knoppix doesn't support nforce2 nic's or some broadcom kt400 nics, but overclockix DOES. It doesn't support the 10/100/1000 NIC's though, not yet...
I also wrote a bunch of scripts to make using the distributed computing clients, samba, and vnc very easy.
Pics-
KDE
KDE
KDE
KDE
IceWM
Opera
xchat
gaim
gimp
xmms
xine
karamba
openoffice
ncftp
Apache
VNC
mozilla
dbench
cpuid
folding@home
seti@home
prime95
memtest86
Pics-
KDE
KDE
KDE
KDE
IceWM
