- Sep 27, 2003
AB9 QuadGT Cannot install O/S - everytime boot to floppy or CD the system reboots
Abit AB9 QuadGT with E6400
2x1GB Crucial Tracer Ballistix PC2-8000
OCZ 600W Power Supply
X-Fi Fatality Sound Card
2x74GB 8mb cache Raptors
NEC 3540 IDE DVD Burner
3.5" Floppy Drive
NOT overclocked
Watercooled CPU and GPU, no leaks
Here is a summary of basic occurrence/attempts:
I used the RETARD method of booting to CD and creating the floppy... Abit's too cheap to make one themselves.
The motherboard would make the BEEP BOOP BEEP BOOP [infinite cycle] sound when you turn it on, so I had to go and disable the sound for when CPU Fan is at 0rpm (since there's nothing on CPU header b/c I'm on water)
Then I enabled RAID for SATA in BIOS and rebooted
The motherboard REFUSED to give me the CTRL+I option to enter Raid Utility (I didn't even know shortcut anyway). It would ONLY show the JMicron utility where it says "Push any button to continue..." Even then when I pushed any button it would NOT go to JMicron Raid utility.
So... I disabled the JMicron controller. After doing so, I was able to FINALLY (after 2 hrs) see the CTRL+I option to create the raid array on my 2 raptors as 128kb raid0 stripe.
Rebooted after creating Raid. Now, I couldn't select my DVDRW as 1st boot device until I enabled the JMicron sata controller back. (does that make sense?)
Finally, I was able to boot from CD, BUT... as it begins to load the CD it says "SETUP IS INSPECTING YOUR COMPUTER'S HARDWARE CONFIGURATION" and instantly after the computer reboots.
So I figured, why not flash the bios... well, I created the floppy and all to flash bios, set 1st boot device to floppy, stuck in floppy, saved and restarted, and whenever it starts to boot floppy, the PC reboots.
So, I figured oh maybe it's cuz of the CPU fan header not in use... disabled that and still no go.
No matter what I do... this board has something else up it's sleeve... I originally had other problems initially, but right now I just can't get the Raid Utility to show up unless I disable the JMicron controller, and I can't boot to CD or DVD when I have the JMicron enabled...
I think I can only boot to CD if I have SATA set to IDE instead of RAID... what the heck????
Should I RMA? I don't wanna spend another 4-5 hours on this junk tonight.
3.5" Floppy Drive
NOT overclocked
