you know, i know this question should have quite a bit of crossover into the storage space and HDD forum, but i'm still not certain that i understand the serillel system that they're talking about... parallel and serial drives... these are 2 different types of hard drives?
the things i understand about this whole system are this...
i understand that serial is faster than parallel, but i don't know why that is. when you say serial i think "daisy chain" and slower. if you say parallel i think independant/faster. apparently thats not so...?
the things i don't understand about this whole system are this...
yes or no - there are two types of HDD's... serial and parallel. if yes, whats the difference? if no... what the hell?
as far as i knew, serial ports and parallel ports only existed on the back of the motherboard on old systems for things like old *** modems and printers and junk... and then you had your standard IDE channels which you connected your ide devices to (hard drives, cd roms, etc etc etc). and if it wasn't an IDE channel then it was a legacy port for the disk drive, or they were RAID channels controlled by the highpoint...
now, as i understand it that is not the case??? one set of these channels are called serial ports and one set of these are called parallel ports? yes? and apparently they can ALL be controlled by the highpoint and be part of the raid array yes? which one is which?
and how do they combine serial with parallel? (a pic would be helpful
sorry. this whole thing has got me confused. i've been doing computers for awhile now and have never paid much attention to the data storage aspect of it - now i feel like i'm in the stone age suddenly. how embarassing. a pic or diagram of the whole setup would be incredibly helpful as the morons who built the press release web page for Abit obviously believed that a crappy, dark, grainy, dinky-*** thumbnail of the whole schebang assembled on someones livingroom carpet was going to give joe schmo (me) even the faintest idea of what they're talking about.
all i see is 2 less channels for RAID on a motherboard that is suppose to be an upgrade, a chipset that still won't support 400mhz (but wants to quite badly like the last one), and now i have to deal with the PS2 ports again because everyone whined about them so badly when they went missing from the MAX1 board (which was a brilliant move IMHO). the only reason i'm holding out on this thing is because there appeared to be so much problem with the NIC on the other one that i wanted to wait till they got it worked out. instead they came out with a whole new board hopefully with the NIC problem whipped...
anyways, thanks in advance for the input. sorry if it's slightly off topic, but this is the only board that claims to be able to do it.
RSB
