Actually, with a QX, I would have to say that the QuadGT is a slightly better choice. Neither board will hinder your speeds due to the unlocked multiplier, but you will likely get slightly better performance at the end of the day with the QuadGT. It allows for more FSB, and also has VTT adjustment in BIOS, which is not very useful for most, but is for quad core.LordFrank said:So, with a QX6700 CPU, I'd want to stay with my original plan of getting the AW9D-Max then?
Gautam said:Klown, try jumping straight to 300...the 800MHz strap is probably precisely why you got stuck at 260. Unless you set it manually, you probably need booting at 266 at least for the 1066 strap to be activated.
The point at where you were that caused the corruption is what's sometimes called an "FSB gap."
