- Jan 24, 2006
- Abroad...
Right, so I might finally take the big punge into watercooling... haha pun.
The last couple days have been spent reading stickies from a couple forums for watercooling. Sadly, our stickies seem a bit dated so I am here to ask some questions. I am looking to start off with CPU only loop and possibly later add NB. Much later, I may add a GPU block but I have no plans to as of right now. Price really isnt an issue with me, I am just looking for the best and to have "room to grow" to add blocks later. With that in mind I have come to these parts:
Preliminary setup:
RAD: TFC X-Changer Triple Radiator 360
http://www.dangerden.com/store/product.php?productid=337&cat=99&page=1
These are supposedly better than the Thermochill PA120.3 and use copper for the water chambers for better heat dissipation. I had been torn over the 120.2 vs 120.3 version for a cooling capability / bulk size hassle standpoint. Open to suggestions for 120.2 vs 120.3 for cooling capacity / mounting advice.
PUMP: MCP355 /w Laing Res attachment or MCP655
http://www.frozencpu.com/products/7...Pump_Attachment_w_MCP-350355_No_Fittings.html
or
http://www.frozencpu.com/products/6...38_Conversion_Kit_317_GPH.html?tl=g30c107s154
I have read that basically the MCP355 is sufficient and with the Laing Acrylic Res attachment is even better. Others say the MCP655 is king, but it dumps a lot of heat into your loop. Advice?
CPU Block: D-Tek Fuzion v2 /w quad insert
http://www.jab-tech.com/D-tek-Fuzion-V2-pr-4155.html
http://www.jab-tech.com/D-tek-Fuzion-V2-Quad-Core-Insert-pr-4154.html
Basically most reviews I have read says this is the best Quad cooling block available. I think the only competition is the Apogee GTX, but I am fairly sold on the Fuzion v2.
RES: Need input.
So far the Laing Acrylic attachment in combination with the MCP355 seems the cleanest I have seen.
I have reservations with the res being mounted on the pump, basically making it at the lowest point of the entire loop. The CPU block and Rad would be higher elevated. Isn't this an issue?
TUBING: Tygon R-3603 7/16" ID 5/8" OD
http://www.jab-tech.com/Tygon-R-3603-7-16-ID-5-8-OD-Chemical-Tubing-AAC00033-pr-3957.html
This stuff seems to be what everyone recommends. Less prone to clouding etc. My loop will be all 1/2" ID so they say this tubing size fits tighter and doesnt restrict flow.
I think that about covers the parts. My biggest concern is over the Rad. I plan on placing it externally, but really am at a loss on how to accomplish this. Where / how can I safely mount a 120.3 radiator. Would I really lose much performance using a 120.2? I am sure it would be a lot less hassle finding a place for it.
Next, I really couldnt see any posts about. Does anyone need or use PTFE tape? (Plumber's tape / Teflon tape) This sounds like it would ensure better seals on the barb attachments. I dont really see PTFE tape listed on most watercooling vendor sites, so I guess the o-rings work just fine? Just a bit concerned putting a non-taped loop into a few $k system.
Finally, hose clamps. Do the Herbie clip nylon ones hold well? I dont want to damage the tubing with the metal worm-drive types. Advice?
I basically want to take my QX9650 to the next level. I know my CPU has a lot left in it, but I feel really held back by the lack of heat dissipation in my Air cooling. It would be nice to see 4.2GHz-4.4GHz 24/7 use. Am I underestimating / overestimating? Am I crazy spending ~$400 for just a few hundred MHz more?
Any advice is welcome!
Preliminary setup:
or
RES: Need input.
