oddly enough system booted, albeit, very SLOW. reset the values back to auto as I did not want to fry anything until I got a response from you. Wasnt sure what value as noted they start from lower value then as list goes down to higher value
after i set them to X9 what am i looking for? to help me better understand.
with x9 on both of those, according to cpuz i am around 3199-3200 .. when at stock its around 3214.. just to give you an idea.
Surgery went well. Nothing serious. Had the old prostate roto rooted. Only problem has been some nausea from anesthesia.
Go ahead and take the CPU NB VID off of Auto. Then it should allow you to either choose 1.2 volts as a manual option from a list or just directly enter the desired value via keyboard. Let me know how that goes and then post those three pics from CPU-Z. The CPU NB is part of the IMC (Integrated Memory Controller) and is found on the processor die. "AUTO" hides options in bios. If you don't see what you are looking for, take it off Auto.
I set the volt to 1.2, heres the latest cpuz screens. thanks for your help thus far. headed off to bed, have early morning ahead of me. I will check in when i can.
when they pull the catheter and I have to pee through a traumatized urethra.
