- Dec 27, 2008
Let me be clear on what you are asking me. Sorry, I just had surgery two days ago and the hydrocodone makes my thought process a little fuzzy at times.
Sounds like you are asking me if you put the X3 Rana in your wife's computer paired with the GS 8400 will it be adequate to run the video at 1280x768 for everyday computing. That's one question, correct? The answer would be "yes". No question . . . a long as the video card itself is capable of producing screen resolutions at that pixel level. You can easily check that out by researching the manufacturer's website for that product. The limiting factor there would be the video ram amount, 256 mb, right?
The other question concerns a CPU-demanding game your wife likes to run and you are wondering if the X3 Rana/GS 8400 combo will handle that. Correct? Well, that's harder to answer because it's sort of the same issue as you have been dealing with all along. To answer the question, install that game on your computer and try it out before you remove the Rana.
