OK well you still have all the green stuff turned on, have you read that guide?? You need to disable Cooland quiet, c1e C6 epu apm all in the bios. But I don't know how much headroom you're going to find on manual settings. Youe motherboard isn't ideal for Overclocking an FX cpu. If you look at the CPUTIN temp the max for that is 70c and you're already at 65. Try setting a manual voltage of 1.35v to the V_Core and see how high you can take the multiplier before it crashes, I'd start at 17.5 if it boots and runs P95 keep an eye on the temps.
