Actually I have a question...
I also use a benchmark called WPrime and I get between 12-13 secs when I am overclocked.. but if I use stock speed, I get over 15 secs... Same thing happens with AIDA64's benchmark.. I get much higher scores at stock speeds vs overclock...any idea why this is?
The LESS time to complete WPrime all the BETTER. Got to know whether lower or higher results are best. In the case of WPrime...LESS is much BETTER.
RGone...
Recommended boards for overclocking on FX, from best to worst:
Crosshair V Formula
990FX Extreme9
GA-990FXA-UD7
Sabertooth 990FX
Fatal1ty 990FX Professional
GA-990FXA-UD5
990FX Extreme6
GA-990FXA-UD3
GA-970A-UD3P
Other boards need not apply.
cool beans.. I will leave it running Prime95 til I get home today just for measure and I will report back once I get home - thanks guys for the great info and your patience.
I had a machine with a 1070T lock up overnight can't remember if it blue screened. The cpu was dead as a doornail after that. On topic I have a 6300 that is running at 4.7 GHz in a Sabertooth 1st generation and the heat is more manageable than when I had an 8350 in it. The 6300 is a very good performer at 4.7 GHz vs 3.5 stock.
good to know... I guess I won't be doing that again , I guess I got lucky this time.I was on the phone with a bud of mine shooting the breeze and him glancing at the TV while we talked. Behind on the floor about 12ft away was a board he was testing with P95 Blend mode. I heard him shout and wondered what the hey...about 5 mins later he was back after unplugging the power supply since the VRM area had been ablaze. That is why I don't leave P95 to itself. YMMV. He could have lost his home had he not been home and 12ft away when he realized he was blazing or make that the mobo.
RGone...ster.
Anyway, I thought the combo of this FX-6300 and the HD 6970 was going to be spectacular.. I am not impressed. I used to have a Phenom 960 3.4ghz quad and an HD 5870 that pulled very similar numbers if not the same... oh well.
RGone...ster.
Need to clock the 6300 higher than 4.2Ghz...
An FX @ 5Ghz is equal to that of a Phenom @ 4Ghz.
I thought Piledriver vs Phenom II ipc was only slightly in favor of the Phenom II's? Like a few percent at most.
magdiel, post some screen shots of the following tabs in Cpu-Z, Cpu, Spd and Memory. It will give us a peek under the hood so to speak. Maybe well see something that can give you a bit more performance. That said, the Fx chips are good chips, but like the gents said above, overclocking it a bit more will really let it stretch it's legs. Problem is, I would not attempt to push that board any harder.good to know... I guess I won't be doing that again , I guess I got lucky this time.
