magdiel it all depends on what you're looking for in the Fx 8xxx/ motherboard combo. If you're just looking for stock settings up to around 4.5 Ghz, you don't need an Asus Sabertooth. I personally tend to stick with Asus boards on my AMD Fx chips because we have seen so many revisions of the Gigabyte boards it is hard to say which one to choose and or if it's going to work. There are other less expensive boards you can get but unfortunately, we don't have many cross through here. The Asrock Fatal1ty Killer seems to be a decent board. Msi has in the past not made very durable boards for AMD and have been know in the past to have failures in the VRM area. I don't know if this is still the case but, again it does make it tough to recommend them. If it were my money and I wasn't looking to really push the chip the Asus M5A990Fx Pro or M5A99X Evo would be on my short list. I own a M5A99X Evo which is very similar to the M5A990Fx Pro and it works well up to about 4.5 Ghz.perhaps.. that'll be an extra $30 tho.. but I've learned that cheaping out on a motherboard has caused me many issues lol
...Okay I hear you talkiing about another mohterboard when you just bought one. You like its' speed with SSD vs what you had and your wife still has old SSD speed and you can make a proposition in your mind that giving your wife your board and getting you another will be just aces. I fully understand since I am trying to finish up the crossover from doing just that very thing.
But here is the big booty kicker. Your cpu is bad unless you give her your slightly flawed FX-6300 which she will never know good or bad about and get her working FX-8350. She just wants to use the computer. At least most of them are that way.
Wow we got that swap made and now we need to get a mobo for "your" FX-8350. Get the Sabertooth 990FX R2.0 Get out of your rowboat and get into something with a V-hull for a smoother ride and get some gas engine propulsion so you are not always thinking you are rowing/pushing more than riding. $30.00 over two years ain't squat. I am betting as Me Now Americans, most of them/us waste that $30.00 in a month and neverstop to think about it. I know I probably do by feeding my dog table scraps I "purposely" save for him. It is all perspective. I am not so blind as I once was...but am also h*ll of lot older today.
But the choice is still up to you. AND do not forget that even with the board you have now...COOLING, MAKE IT BIG COOLING would change your entire outlook on overclocking computers. Day and night when I jump off this FX-8350 on air right now to my FX-8350 on some shazam water cooling.
RGone...
pretty intense with all the effects she uses and such...I just feel she is not taking advantage of the full potential of the 8350 with her current board.
Haha imagine that!!!Okay well I hear what you say also. Get her 16Gig of ram running at DDR3-1866 and get her enough beans to run 4.8GHz and she will say...dang honey what did you do to my stuff? You are such a sweet man. Hehehe. And you keep what you got. Now that sum funny shett.
RGone...
haha.. yeah - but in order to get her 8350 to 4.8ghz she needs a major upgrade to her moboOkay well I hear what you say also. Get her 16Gig of ram running at DDR3-1866 and get her enough beans to run 4.8GHz and she will say...dang honey what did you do to my stuff? You are such a sweet man. Hehehe. And you keep what you got. Now that sum funny shett.
RGone...
I do notice that even when getting a stable 4.4ghz (3-4 hrs of prime95).. most benchmarks rate lower than 4.2ghz & 4.1ghz..why is that? 4.3ghz is horrible.
Why? Don't know!
Per Centage Increase
Have seen something very similar for any FX processor and it might occur with any processor ever made. Have not noticed such until I started looking very hard at just how hard to really push an FX processor since they get so d*mn hot and draw so much current thru the VRMs on the mobo. So I just began to calculate how much of an increase in performance there was by stepping up to the next speed and the next.
Now on a case by case basis, it might be that like in anything else there are just flat out resonating sweet spots. Might be nearly anything and I doubt I have the skills or equipment to dig out the actual cause, but I know of the situation and plan my cpu speed stops around what I have seen.
RGone...
Man you really need a sig magdiel, luckily I know what that is. You're using a Gigabyte board and that's common when OCd. You need to have APM enabled and your core boost set to the same speed as your overclock and it should stop.
