You're FSB is still oced, it should be at 200 Mhz. Also as Scotty said your ram is off it should be ay 800mhz with the timings set at the XMP profile in your Cpu-Z spd tab.CPU-Z CPU
Memory
SPD
HWMonitor
These screens are after a 24 min prime95 BLEND test, with RGones suggested setting changes made to BIOS. (DISABLED C1/E, C6, Cool N Quiet, APM, TurboCore.
ENABLED HPC )
DRAM Frequency is still showing a little high even though FSB is now at stock. Wonder what's going on there? HT Reference and NB are also a little out of spec.
Yes and you can also tighten the timings a bit on the sticks, by setting them to the XMP-1600 profile 10-10-10-27-41
Bus Speed is 200.63. Take that 0.63 and multiply times the HT Link Speed multiplier and the Ram multiplier and you will get that "off" amount. Easiest to see at HT Link Speed in CPUz CPU Tab with an 11 multiplier. 2206.97MHz. Almost dead on that 0.63 overage of the Default Bus Speed. Heck my CHV board does it and most any brand and model has some amount of error at that location.
The only motherboard that I have personally seen that seems closer on oscillator speeds is my Asrock Fatal1ty 990FX Professional and it shows Default speed of 200.0. That is as close as I have ever seen on any mobo.
RGone...
I realize that ocillators are seldom precise but the variance the OP shows seems to be more than what I'm used to seeing in the boards I've worked with.
That looks good, Piettu but you are at the top of the acceptable temp envelope. No head room there for overclocking.
