Hi everybody,
Thanks to the overclockers and another forum, I have started my OCing trials and this is currently where I stay at with stability confirmed after hours of gaming and Prime95 test (max CPU temp has hit to 41Celcius on full load),
Check System
@4.130 Ghz I am using 1.425v for the CPU.
NB and Htlink is around 2065mhz.
Cooler kit: Air : Noctua NH-14 (17C idle - 41C full load prime)
RAM kit: Corsair Dominator 1866mhz
So here comes the question;
Concerning the NB speed, does it improve performance OCing it as well or does it just create instability if I OCed more? I stay as closer as possible to 2ghz on NB .
Long story short, is it worthy to OC NB?
And do you think if it is feasible to vmod with my air cooler in use and go for 4.5ghz=just for benching . I honestly don't even know what vmod is and if it is possible to do it with 1055t. Just asking since ppl are talking about it.
Check System
