Hey Dj,
You seem to have the exact same problem which I had when I hit to 250fsb barrier. Guess what ? Now I am all the way up to 295mhz fsb with 14x multiplier.
Here is what I did and how I did it,
First of all you need to start with;
-14x multiplier
-Cpu core v 1.425 (which is actually the default volt when turbomode is activated)
-Set FSB to 255mhz
-Make sure your Htlink and NB speed is hitting no more than 2000mhz. (play with it and you will find a nice multiplier that lets NB stay lower than 2000mhz.
Set TurboMode Disabled,
Quiet Mode disabled,
PCI spectrum disabled,
CPU Unlock mode disabled.
Now here is the most crucial thing,
Set your RAM CAS to a slower ground such as 10T or even 11T
I am using 10T 9T 9T 24T and so far no issues.
If this method fails try such 10T 10T 10T 27T or 11T 11T 11T 27T
And if you can now boot,
VERY VERY VERY IMPORTANT,
always carry on with 5 fsb increment. (You are getting the system ready for it by doing this)
Dont forget to set the NB-HTlink-Ram multiplier as you set the FSB to higher clocks.
With every increment check it with cpu-z & hardware monitor. Be patient, dont rush to 300mhz at once.
With stock cooling and without any extra voltage (as v.1.425 is the factory default for 1055t on load) you should be able to boot up to 286 FSB which should give you 4004mhz in return with 14x multiplier. (WARNING if you want to use it daily buy an aftermarket cooler)
Since there is no extra voltage rushed to CPU, it is not a fatal operation (considering you keep HTlink and NB at around 2000mhz)
IF this suggestion fails in 255mhz fsb,
- Give one more step of voltage (like 0.020v I suppose) to NBridge
- Give one more step of voltage (like 0.020v I suppose) to Vdim
- Set CPU with v.1.45
and see how it goes
I hope you can make it. I am currently on NOCTUA 14H
with 4130mhz , 14x 295mhz FSB v.1.425 CPU 1055T 6x cores enabled
ram set to 10-9-9-24 (that was edited as I typed wrong)
CPU cores are 17C idle 40C on heavy load with Prime and with gaming. No issues .
over 295mhz FSB I can't boot though and it is most likely to do with my dominator Rams from Corsair +1866mhz complients but slow T s.
http://img.donanimhaber.com/upfiles/416527/70246226E5264CC3A2AF75AA25755A0D.jpg
